SRS LIGHT COMES ON
Old Nov 22, 2004 | 03:29 PM
soaring's Avatar
Default SRS LIGHT COMES ON
I HAVE A 1994 MERCEDES S320 , WHEN EVER I START THE CAR THE SRS LIGHT STAYS ON, I DRIVE ABOUT 1 MILE AND IT GOES OFF AND STAYS OFF, UNTIL I TURN THE CAR OFF AND ON AGAIN. CAN SOMEONE TELL ME WHAT IS GOING ON? AND WHAT I NEED TO DO TO FIX THIS PROBLEM.
Old Nov 22, 2004 | 05:10 PM
C280 wizard's Avatar
Default RE: SRS LIGHT COMES ON
Sounds like a short or loose wire or could be in the onboard computer. Take it to a dealer as this is a safety. I had a similar issue with my smart key and smart start. My 99 C280 wouldn't start, unless I took the key out and let it sit for a minute after trying to start it. I took it to a dealer they reset the OTC and now it starts, but the smart start is questionable at best!
Old Nov 22, 2004 | 10:32 PM
sleepwalker's Avatar
also it might be low voltage.
Old Nov 23, 2004 | 08:11 AM
Yes, very strong possibility it could be low voltage.
Old Nov 28, 2004 | 02:32 AM
Gary77's Avatar
Hello! Looks like you have a problem with your throttle actuator.
Old Dec 24, 2004 | 11:24 AM
mespe's Avatar
Be aware that the dealer will most likely tell you that you need a new SRS Airbag. The bags I believe have a 10 year lifetime. and since your car is 10 years old it's time for a new one.
Old Dec 27, 2004 | 01:54 PM
neilbaud's Avatar
My SRS light was fixed 3 weeks ago and the reason was Low Voltage as Sleepwalker mentioned it.
Old Mar 20, 2007 | 09:20 AM
everlyne's Avatar
My SRS light stay ON and the scanner says low voltage. How do you fix yours?
Thanks.
Old Apr 15, 2007 | 09:51 PM
  #9
benzo25's Avatar
I had the same problem. Pull your dash instrument panel out, and unscrew the SRS light bulb. That will fix it for sure.
Old Apr 18, 2007 | 02:04 AM
  #10
everlyne's Avatar
Yeah would be nice to close the loop.
Thanks.
azoo
Oct 5, 2009 10:44 AM
susanc
Feb 11, 2009 02:45 PM
nagy1106
Apr 21, 2006 03:17 PM
Cosworthpower
Oct 26, 2004 12:36 AM
pawelek
Apr 5, 2004 06:22 AM
