SLK230 With CAM Sensor Code
Old Feb 9, 2009 | 08:17 PM
sflankey's Avatar
Question SLK230 With CAM Sensor Code
1998 SLK230 with 61,000 miles: CEL with codes P0341 (CAM POS Sensor Range/Performance) & P0410 (Secondary Air Injection Sys Malfunction).
Car is slow to accelerate and tends to bog down on up-hills without down shifting appropriately. Have reset code and returns at varying intervals (intermittent).
Have not found the smoking gun yet. Troubleshooting so far includes: No loose connections, vacuum lines okay, clean MAF, and clean throttle body.
CAM Position Sensor shows 8 ohms resistance both cold and hot. With key ON, voltage is 12 volts & 7 volts at the plug connectors (each wire).
Should my next step be to change the CAM POS Sensor?
Old Feb 28, 2009 | 02:49 PM
sflankey's Avatar
Default Problem solved.
Replaced the Cam Pos Sensor ($140) and all codes vanished. After 2 weeks- no repeat.
Old Mar 5, 2009 | 12:55 AM
fyakin's Avatar
what's the best mechanic that anyone can refer to me.
I have SLK 230 , 1998 and the Camshaft Pos Sensor needs to be replaced.
How difficult to replace it, can I do it myself? If not is there any recommendation reasonable mechanic . I live in Northern California(San Francisco Bay Area)
thanks
Francis
pmckone
Aug 5, 2012 01:35 PM
mcfly
Jun 30, 2011 12:43 PM
owenrich
Feb 12, 2011 08:43 PM
zoober
Mar 8, 2008 12:32 PM
zimmfinn
Mar 9, 2006 11:30 PM
