Seat fuse keeps blowing
JD,
Start by trying to determine which switch position causes the fuse to blow. Next examine the wires going to the seat motor that switch position controls. One of them could have had some of it's insulation worn away or pinched thus shorting the wire to the seat frame. If none of the wires are shorted then you need to check to see you could have one of the seat motors shorted which may have to be replaced. A third option might be, the seat is jammed, try manually rocking the seat, up/down, tilt front/rear to free up the seat. Check for obstructions.
Hope that helps,
Steve
Hope that helps,
Steve
iwmfwo2010
12-12-2009 12:21 PM
