REPLACESING THE DIVERSIDE WINDOW SWICTH
behind the window switch buttons there is a center console compartment. pull up the carpet and you should see a screw, then you can pull up the wood trim around the shifter to replace the switch. the switch should just pull out.
ifthecar
05-12-2013 02:07 PM
