Raising idle 84 380SL
Old Jul 27, 2005 | 11:17 AM
TBenedikt's Avatar
Default Raising idle 84 380SL
I need to raise the idle speed on my 1984 380SL as it is just idling far to low. There are no adjustments that I can see on the linkage so I would assume that adjustments are made at the fuel Distributor. I would appreciate any help that I can get in accomplishing raising the Idle.
Thanks, Tom
Old Aug 6, 2005 | 02:08 AM
shooter's Avatar
Default RE: Raising idle 84 380SL
The idle speed is electronically controlled. The idle acuator or the idle speed controller may be bad. Also check to see if you are getting a closed idle switch at closed throttle.
hooperdoski
Aug 9, 2012 06:54 PM
mp7646
May 25, 2011 01:58 AM
benzpimp
Aug 10, 2006 05:34 PM
Dicker
Oct 29, 2005 08:56 AM
rosenlou
Jul 29, 2005 03:08 PM
