Questions on your benzes, i can try to help!!!
Old 09-08-2009, 12:51 PM
o.naylor's Avatar
Hi, do you give help on vans? I have a mercedes sprinter 308D which will only run for a few seconds. The oil filter has been changed and a bulb was used to prime it. Fuel is getting to 1 and 4 injectors but not 2 and 3.
Can you help?
  #82
Old 09-11-2009, 06:58 PM
l2mb's Avatar
Originally Posted by MEMPHISTRUCK
I have a 09 e350.can a remote start system be put on this car.
no and if u do find someone who sayas they can do it it will be very expensive and cause alot of problems
  #83
Old 09-21-2009, 05:30 AM
sltc's Avatar
Default S320 Gearbox
Hi
Have you ever come across a problem on s320 auto boxes where there is no reverse gear? The car is a 1996 uk model. Sometimes on flat ground there is reverse gear but on an incline the car will not move in reverse. All forward gears seem fine and when moving from N to D you get the usual jerk as the gear engages but nothng like that in reverse. Filter and oil were replaced but on top up it only took 4.5 litres rather than the 6.5 litres suggsted by autodata
  #84
Old 09-21-2009, 11:47 AM
sticknmove's Avatar
Hello, I'm kinda of new to this site. Does anyone know of an aftermarket Catalytic Converter that would work well in an S430? The cost from MB for a new one is out of this world.
  #85
Old 09-27-2009, 03:17 PM
DieselDoll86's Avatar
Default 1982 240d Help
I just bought my first benz, I have been looking all over this site but can not
for the life of me find where my manual door latch for the gas tank is. Thanks again.
  #86
Old 09-28-2009, 08:13 AM
sel320's Avatar
hey
changed both track rod end on my dads SEL 320 and all was done ok and after he went to get tracking done and that went ok but the steering wheel has now to be held fair bit to the right while car is going straight forward, do i either remove the steering wheels and put it straight or take track rod ends off again ?
thanks
  #87
Old 10-03-2009, 07:18 AM
phnthomas's Avatar
I have a 500SEL and I dont know why my battery is going dead after a day...do these cars have a problem with this? I have 202k on it what else can I expect with this kind of miles on it?
  #88
Old 10-04-2009, 01:37 AM
sunny02's Avatar
regfrtg44g4
  #89
Old 10-04-2009, 01:39 AM
sunny02's Avatar
a class auto trans in one gear and esp and abs light is on what can i do?
  #90
Old 10-04-2009, 10:50 AM
e320cdi786's Avatar
HI
I think ive creacked the sump on my e320 cdi help needed asap is it a big job changing sumps
Quick Reply: Questions on your benzes, i can try to help!!!
