Overdrive working?
Old Aug 25, 2005 | 11:30 AM
mvwallyworld's Avatar
Default Overdrive working?
I am a newbe here and a new 1999 sl 500 owner. The question I have is I am not sure the overdrive is working. What rpm should I be turning at 65 mph? Is there another way to be sure it is functioning?
Thanks for any help.
Randy
Old Aug 25, 2005 | 02:05 PM
sleepwalker's Avatar
Default RE: Overdrive working?
you got no overdrive since there is a freewheeling gear inside your transmission. no ratio on 4th gear (1:1)
if you got 722.6 transmission, then it's electronically controlled. 5th comes at 1:0.83
use the manual shift to feel on which gear you are now. it won't damage anything. (for example: if you want to know if you are in 5th gear already, move the lever to "4". if you feel a sudden downshift engagement, it means that you were at 5th gear before moving that lever to "4".)
dobby67
May 13, 2009 03:20 PM
gregb
Dec 22, 2008 08:29 PM
elmo44
Mar 6, 2008 08:25 AM
gireaud
Aug 17, 2007 02:16 PM
MLbenzo
May 24, 2006 10:59 AM
