1983 sl380 will not go into overdrive until car has heated up.
Old Mar 5, 2008 | 05:49 PM
elmo44's Avatar
Default 1983 sl380 will not go into overdrive until car has heated up.
when car is cold the transmission will not engage 4th gear until the transmission has heated up. whassup.
Old Mar 5, 2008 | 09:50 PM
carnut's Avatar
Default RE: 1983 sl380 will not go into overdrive until car has heated up.
4th gear is, I believe, direct, not overdrive. That said, I think its normal. Most emission systems delay last upshift in order to get the engine up to temp. quickly to lower emissions quicker. I presume you've had the trans fluid changed as well as the filter before posting. If not, good idea simply based on car's age. All service manualsstate to verify fluid level and condition of fluid before any further diagnosis is attempted.
Old Mar 6, 2008 | 08:25 AM
elmo44's Avatar
I had the transmission overhauled. It was doing it before and has continued since. It acts like it is vacum relater as i get black smoke out of the tailpipe during shifts.
Freddie Pope
Jun 29, 2009 04:42 PM
fscott49
Jan 6, 2009 10:41 AM
wwickers
Oct 6, 2008 10:17 PM
z492678
Oct 15, 2007 09:27 AM
danfijiboy82
Nov 2, 2006 04:59 AM
