OBD2 monitoring disabled?
Old Feb 5, 2023 | 08:41 AM
dbcl's Avatar
Default OBD2 monitoring disabled?
Tried posting this on mercedesclub.org.uk but replies were basically buy a new scanner and I am quite attached to my present one.
Just picked up my new second hand CL 500 and have been reading the codes.
Seems there are two ECUs to choose from - $7E8 CAN-ID ECU #1 and $7E9 CAN-ID ECU #2, what is that about?
Anyway ECU 1 has far and away the most info and it says "Distance since diagnostic trouble codes cleared - 160KM" which is 28 miles before I collected it (ECU 2 says 65,535KM since cleared).
That wouldn't worry me unduly as no codes are currently showing and EML light is off HOWEVER further down on ECU 1 info it lists a load of monitoring which is disabled, notably misfire monitoring is off (but it does say later on "misfire monitoring completed") see pic below. Is that normal and should I somehow get them re-enabled?
I guess my worry is: Is it possible, with an expensive OBD2 tool that a dealer might possess, to disable misfire monitoring via the tool in order to hide problems from the buyer? Second question - is that what my scanner is showing or perhaps is the ECU clever enough to enable and disable misfire monitoring automatically, when it needs to?
It's a
CL 500 (C216) 2009 107K miles
K1MOTORSPORT
K1 Motorsport
34
Jan 28, 2010 05:46 AM
siliko
Apr 13, 2008 04:11 PM
siliko
Apr 13, 2008 03:53 PM
star_expert
Feb 15, 2008 11:28 PM
lightnng
May 3, 2006 02:23 PM
