New member, Mercedes-Benz Master Technician
Tony: I have a 85 300d -How do you detach the spliced end of the cv joint on the half axle to replace a ruptured boot? If you prefer to email the response -weldingman101@yahoo.com-appeciate any help-thanks- James
hi tony!
i have a 1997 e280 with automatic transmission. i put the gearbox to the "d" position. it drives to about 3rd gear and disengages while driving. it wont then re-engage. i switch the car off for 10 secs and switch it on again. the garbox re-engages but it gets to 3rd gear again and disengages again. what is the problem? is it that the auto transmission fluid levels are low?
I need a new engine on my '83 300CD Turbo Diesel. My usually machanic doesn't really want to do it. He is getting pretty old. And one of the engines I am thinking about buying needs to be installed by an ASE certified mechanic. Or I am debating buying a car that has been in an accident that has/maybe had a good engine or buying a rebuilt one on-line with a warrentee. But there is a list of things that have to be done to validate the warrentee that I am guessing are going to be very expensive. Any thoughts? Know any good people on the Westside of LA, CA?
Hi, I acquired a 1998 C230. My inspection runs out late Aug 09. The gas light comes on after running the car awhile and coming to a stop/slow speed for any reason.... I would like to fix this myself if at all possible.... any suggestions? THX
Hi Tony,
I just bought a 86 190D, got it for real cheap but it has some issues. When you turn on the right blinker, lights, or press the horn, the windshield wiper turns on, but the functions themselves don't actually work. I don't know much about wiring, but could you let me know where to start? Also, when I turn the key off the engine still runs, luckily its a stick, so I just kill it in first gear, but I would like to fix the problem. Let me know if you have suggestions. Thanks.
Hi Tony
I took my CLK to a mechanic to diagnose the check engine light warning, It is the Air Mass Meter.
Were can I purchase an Air Mass Meter for my 2001 clk320? Also after I install it will that turn off the check engine light, or does it have to be reset?
I have a c320/2001 and need to replace the crankshaft sensor. need help with the how to. I was told it was located on the bell housing of the transmission. Need help. I got to go back to work on Monday.
My C230k 2004 sedan have a diagnostic report fault codes P0452 and P0172. A mechanic told me that had problems with the pressure sensor low input and need to replace the fuel pump
assembly. I was searching the web and I find that this model has two fuel pumps one in the passenger side and other on the driver's side. Which of the two is the report? Anyone know what the replacement number for this part? And install it.
benchmark88@gmail.com
