leaving for a while
Old Dec 14, 2004 | 04:21 PM
kaan's Avatar
Default leaving for a while
I am going to be leaving my car for 1.5 months. It is going to be kept in a closed garage so i don't think that i should change the coolant or something. It has 1000 miles on it. What are the things that I should do before I leave?
Old Dec 14, 2004 | 05:31 PM
MercedesMan300D's Avatar
Default RE: leaving for a while
ok, heres what you do... fill the tank, add some fuel stabilizer (sea foam, sta-bil... both work great) drive it around the block a few times (to get the stablizer worked into the system)
top the tank off compleatly (so it wont rust ), and then disconnect the battery, or put a battery tender on it
I think thats all, good luck
Nate
Old Dec 14, 2004 | 05:44 PM
kaan's Avatar
what would happen if I do not disconnect the battery other than the drain?
Old Dec 20, 2004 | 03:09 PM
Peter Guenther's Avatar
Dont disconnect the battery, put a trickle charger on it, if the battery runs down ( not in six weeks) you will have to recode the radio, resynk the windows on some models. I left my 01 E over the summer and the mice made a home on the engine it still started, I guess you could throw in a hungry cat, but then there are other issues.
Old Dec 26, 2004 | 08:35 AM
kaan's Avatar
dude, how did they get into the engine?
Old Dec 26, 2004 | 12:09 PM
Lugnut's Avatar
You don't need to do anything special for 1.5 months. A Battery Tender wouldn't hurt, but isn't absolutely necessary.
Gas starts getting "bad" after about 3 months, but it's still good enough to run the engine for awhile afterwards. I never put gas stabilizer in my lawn mower and it starts right up every spring.
The battery will be a little low, but should still start the engine. If not, you have other problems.
Do a search here on "storage" to get long-term storage info.
Old Dec 26, 2004 | 05:24 PM
kaan's Avatar
i do not think that the car will start when I arrive. It sometimes drains the battery when I leave it for a week.
Old Dec 26, 2004 | 07:02 PM
Lugnut's Avatar
Put a battery manager on it then. A Battery Tender is about $20. Everything else should be okay.
wicked.ludicrous
Jul 13, 2011 08:20 AM
LMurthwaite
Jun 22, 2009 10:18 PM
jbou
Feb 19, 2006 10:42 PM
kaan
May 7, 2005 09:02 PM
kaan
Apr 25, 2005 10:09 PM
