Intake Air Temp Location
Old Nov 10, 2008 | 12:33 PM
Sprint97's Avatar
Default Intake Air Temp Location
Can anyone tell me the location of the IAT censor? I have a 2002 S430.
llbrew91@aol.com
Old Nov 11, 2008 | 01:04 AM
snanceki's Avatar
Default RE: Intake Air Temp Location
The engine AIT is part of the MAF sensor. Many people think the MAF sensor is the AIT thermistor. You can't actually see the MAF sensor even when the sensor is removed from the housing that holds it.
The cabin AIT is mounted on the plenum chamber which is the "box" (black) under the hood with the grill on top near the screen. Two wires go to the sensor which is held on with a couple of screws. Whilst you are there ensure that no water has collected in the bottom of the plenum due to a blocked drain (very common w220 problem)
Old Nov 11, 2008 | 12:13 PM
Sprint97's Avatar
Thanks for the response. I am looking for the AIT for the engine which apparently is entigrated with the MAF sensor housing. Can you tell me where the MAF sensor is located?
Old Nov 12, 2008 | 01:12 AM
snanceki's Avatar
Unfortunately I can't post pictures for reasons I have never been able to fathom.
Maybe somebody else will send you a pic.
Basically it is in the inlet track AFTER the filter BUT before the throttle butterfly. This may help or not dependent upon your understanding,
Its a black plastic tube like thing with a sensor screwed into the side.likely using "special" anti tamper security Torx screws.
To gain access you MAY have to pull the air cleaner off. Jerk upwards.
I don;'t have a 430 so can't be 100% sure where it is located without looking.
Stuart
Old Nov 12, 2008 | 08:07 AM
Sprint97's Avatar
Thanks very nuch. I do understand. I worked on vehicles for many years including racing ingines with fuel injection systems. Never on eletronics.
Luther
GotRide
Apr 8, 2008 10:24 PM
blackho230
May 18, 2007 05:54 AM
Power Man
Jan 23, 2007 01:13 PM
roaster
Nov 9, 2006 10:30 AM
miishmiish
Jul 9, 2006 03:13 PM
