Injection pump--fuel leak
Old Nov 30, 2006 | 01:49 PM
melli33's Avatar
Default Injection pump--fuel leak
I have a 1995 E300D. It has run roughly since it got cold (about a month ago) and then just the last week, it also began to be harder to start. The hard starting did not coincide with cold weather.
I was told by the dealer that the problem is the fuel injection pump, which needs to be replaced. It would cost $2500.
Is there any way I can keep using the car and keep starting the car without making this costly repair right now? Would a block heater help? Fuel treatments? Any ideas?
Old Nov 30, 2006 | 05:29 PM
Charles Munn's Avatar
Default RE: Injection pump--fuel leak
ORIGINAL: melli33
Maybe you could add an electric fuel pump near the fuel tank? Of course if the fuel injection pump totally fails you're SOL.... Still, it may not weaken any further, so who knows? Not me because I wouldn't make a pimple on a good diesel mechanics butt....
At anyrate, if you dedide to try it, you should be able to buy an electric fuel pump for under $100.00.
Henry Schuman specializes in older Mercedes, but he's been a diesel mechanic since 1968 and has very reasonalble prices for all autos and all years.
or Kent Bergsma of http://www.mercedessource.com may have some suggestions...
So might Russell of http://www.dieselgiantl.com
duresmith
Feb 17, 2014 10:52 PM
seadog
Mar 5, 2011 11:11 PM
dagumol
Nov 4, 2009 05:28 AM
Bigeasyherb
Jan 28, 2005 12:57 AM
