Help...removing a right front axle from E500 4matic???
Try removing the front right motor mount and that should give u enough space to wedge a pry bar in behind the inner cv joint housing to pry it off the engine block. Just make sure to use a brass punch to reinstall ur axle instead of just using a hammer. Brass is a much soft metal and it won't damage the metal that the axle is made of. Hope this helps.
CHEERS!
CHEERS!
