Glow Plug Relay Issue
Hello All,
I've recently been running into some issues concerning my glow plugs not warming. My first steps were to remove the metal case around the relay that was under the dash to look and see if there was any damage to the unit. After inspecting it and plugging it back it it clicked and my glow plug light came back on no issue. Over the past few weeks it will click over by itself or id manually hold it in place and the light would switch on and I'd be able to start my car no problem. However recently the light became dimmer until now it doesn't even come on at all. But when I manually hold the relay over my other dashboard lights dim. I checked all my fuses my battery and even cleaned the connection spots. Still no solution. I have a new manual override glow plug system coming in the mail but was wondering if I could somehow hot wire my glow plugs directly from the battery.
TL;DR Need to know if and how I can manually hot wire my glow plugs using a wire from the battery until my permanent fix comes.
Thanks all anything is appreciated
Cantukeeslim
Jun 4, 2009 01:06 PM
