GLK 350 Questions
Old Mar 4, 2019 | 12:03 PM
Joe Kowalski's Avatar
Default GLK 350 Questions
Hello,
I drive a 2010 GLK 350 (premium package) Mercedes. I'm having an issue with the coolant system it seems. The normal running temperature is 80C. But my engine seems to be running below that by 5-10C or so. The check engine light is on and I went to AutoZone to see what the diagnostic said and it reads....
P0128: COOLANT THERMOSTAT (Coolant Temp Below Thermostat Regulating Temperature.)
What do I need to do to fix this problem? Any help or advice would be helpful.
Also, my computer on my car is telling me that a "tire pressure monitor system" sensor is faulty. I'm guessing just one needs to be replaced but I'm not sure. What is the best / cheapest way to go about this issue? I really want no check engine lights or tpms lights on my sticking out.
Thanks!
Joe
Old Mar 5, 2019 | 02:33 PM
PelicanParts.com's Avatar
Hello Joe and welcome to the forum! If you're using the correct coolant for your MB, then you may have a faulty sensor that needs replacing - I would chat with an indy shop about this and see what they recommend. Same goes for the TPM sensor - that should be an easy replacement.. We're happy to assist with any parts if needed. Please let us know if you have any other questions.
Joe Kowalski
Mar 3, 2019 06:27 PM
khowar1x
Feb 21, 2009 06:09 AM
cliff
Sep 1, 2008 04:44 PM
kfolta
Mar 26, 2008 04:19 PM
dsc91
Nov 19, 2007 09:59 AM
