fuel line diagram
Old May 7, 2012 | 09:25 PM
mbtruthseeker's Avatar
Default fuel line diagram
I am new to this forum. I have a 1979 300sd which has a vegetable oil conversion system which I want to unintsall. I have searched the manuals and cannott seem to find a fuel line diagram in order to reattach the fuel lines properly. Can someone here direct me to a source for a fuel line diagram?
thanks
Old May 8, 2012 | 07:36 AM
Originally Posted by ForcedInduction
Its a very simple system.
Bottom of the tank
Fitting from 46mm hex- Supply
Straight fitting- Return
Injection
Lift pump- Rear in, forward out
Filter- In and out are marked with arrows, out goes to left side of the pump
Return from the pump- From right side of pump to the 3-way banjo fitting on the top of the filter
Return from the injectors- To the 3-way banjo fitting on the top of the filter
Return to tank- Use cigar hose to prevent thumping noise in the chassis
thanks. excellent.
Kevin Rattai
Oct 2, 2013 04:56 PM
RngTrtl
Sep 19, 2008 11:33 AM
kimo
Feb 11, 2004 01:50 PM
Lugnut
Jan 23, 2004 11:10 PM
JohnX
Oct 21, 2003 06:35 AM
