Fan Problem in CLK 320
Old Mar 25, 2010 | 06:50 PM
briangould's Avatar
Default Fan Problem in CLK 320
Hi - I have a two door 1997 CLK 320 Mercedes & the fan goes on about 5-10 min after the car is turned off & then continues until the battery is dead. The engine temp is normal & the fan sounds like it's running really fast & LOUD - sounds almost like a gardener with a leaf blower is in my driveway. Any suggestions on what might be causing this little tantrum? Thanks!
Old Mar 25, 2010 | 06:54 PM
chassis221's Avatar
usually its a bad fan....there is also an output stage control unit for the fan that go bad but usually when they go bad the fan doesnt work at all.
Old Mar 26, 2010 | 12:56 AM
briangould's Avatar
Default Thanks!
Wow - what a prompt reply. I can tell I'm gonna like this site & I just joined today. Thanks for the tip...I'll be sure to check into that.
Thanks again,
Brian
Old Mar 26, 2010 | 04:44 PM
NAZ's Avatar
NAZ
sounds like you fan motor its shortin internally did 1 not long ago..it was on w204....done this on w208 as well many times lost cont lol...
Old Mar 27, 2010 | 02:41 AM
briangould's Avatar
Default Thanks Naz
yea - I was wondering whether it might be something like that. At first we couldn't figure out how the battery died after arriving back at the house after it was parked 3 weeks. Then we hooked the battery charger up to it & the fan went on right away & it seemed to be going just as fast as it does when the car is running. After it was charged, I drove it around for a while, shut the car off & 5-10 min later the fan came whirlling on again at full speed & wouldn't stop until I took out the fuse. I jiggled some stuff around to check the connection & it hasn't happened again since yesterday afternoon, but I'm thinking it's only a matter of time.
So a short in the fan motor, eh - I wonder how complex (or expensive) the procedure is to to fix it?
Definitely appreciate all the help! Thanks again...
rschleicher
Mar 10, 2014 08:22 PM
seadog
Feb 16, 2011 07:17 PM
clk350
May 25, 2006 10:43 PM
CanadianEh
Oct 11, 2005 06:16 PM
haidarsaid
Jan 22, 2005 11:51 PM
