Engine Runs For 10 Sec & Stops
Old Mar 20, 2004 | 09:11 PM
cmswin's Avatar
Default Engine Runs For 10 Sec & Stops
I have a 190E 2.6 89 model. Car has setup for a year ran good when first started then quit after driving 20 miles. Found rust in fuel tank change fuel tank cleaned out al fuel lines put new filter on. The car will start fine and runs for about 10 seconds the shuts off if you give it gas when you start it it cuts of immediately. The gravity flow is fine the pumps seem to have good pressure. Mechanic thinks it is the pumps but they were working before the system picked up the bad gas. Does anyone have any ideals?
Old Mar 27, 2004 | 10:10 AM
cmswin's Avatar
<IMG src=smileys/smiley1.gif border="0">We solved the problem, new pressure control valve, filter and adjusted the air flow couln't run better.
albertlai
Jun 19, 2017 09:13 AM
prp25brad
Dec 11, 2007 12:06 PM
patrick 450sel 1980
Sep 8, 2007 10:16 AM
nkosi
Jun 12, 2005 10:45 PM
