Engine noise
Old Jul 4, 2006 | 03:40 AM
Battlecat714's Avatar
Default Engine noise
On my 95 e320, there seems to be a constant cricket noise coming from the front of the engine block, radiator, condensor area. It sounds when the car is hot, it's not so loud when idling or changing from "P" to "D," but once you're driving, either foward or reverse, it gets louder and faster (1000-3500rpm). I could deal with a one or two engine noises but this one's really obnoxious. Thanks in advance.
Old Jul 4, 2006 | 05:55 AM
sleepwalker's Avatar
Default RE: Engine noise
listen and pinpoint the problem.
if it goes off by praying water on the belt, then.... try to find out.
remove the belt and turn every pulley by hand. does it produce the same sound?
Old Jul 4, 2006 | 06:49 AM
how do I go about removing the belt?
Old Jul 6, 2006 | 01:00 AM
anyone know how to remove the belt?
Old Jul 6, 2006 | 03:05 AM
jmang09's Avatar
pdf file for belt removal:
www.blueboxpcs.com/drivebelt.pdf
hope it works for you.
j-mang
Old Jul 6, 2006 | 03:44 AM
perfect, thanks mangg
Old Jul 6, 2006 | 03:51 AM
here's a clip of the cricket http://www.youtube.com/watch?v=Y2E3Vxe5ddU]the cricket
Old Jul 6, 2006 | 07:07 PM
jmang09's Avatar
saw the clip....weird noise....it doesnt seem to increase with engine speed? it could be your fan clutch, or the fan itself since the noise to me seems constant. try spinning the fan with the engine off..see if you hear that weird noise. Good luck.
j-mang
Old Jul 7, 2006 | 01:24 AM
  #9
ORIGINAL: Battlecat714
It does seem to increase with speed or if I lift the throttle it gets louder and faster. So i'm thinking it's the belt which should be changed every 30k miles and I don't remember the last time it was changed. Fan clutch is ok, no noise with engine off.
Old Jul 7, 2006 | 02:35 AM
  #10
jmang09's Avatar
have you tried the old screwdriver trick? Get a long screw driver with the engine running..put the metal end on various parts of the engine (not the moving ones of course) and your ear on the other end..if the sound gets louder then that part is usualyl the problem. I remember on my e320 there was a rickety weird sound and I did that and it turns out it was the tensioner, and the shock absorber on the tensioner that needed to be replaced along with the belt. Anyways..good luck man.
j-mang
timguildford
Sep 5, 2007 07:01 AM
patgrpatgr
Dec 22, 2005 08:36 PM
JC untapped 93 600SL
Aug 23, 2005 07:40 PM
trymonlam
Aug 20, 2005 08:15 PM
CCCP
Feb 18, 2005 05:00 PM
