Engine Light
Old Dec 21, 2009 | 04:24 PM
tstewartfn14's Avatar
Default Engine Light
I have 1998 E 300 TD When it is cold out,15 degrees F and lower when first started sometimes the turbo does not function. The occasions for this are random but only when severely cold. I will drive the car for sometime, usually off and on for an hour, the turbo will start working again but light clears when it feels like it. Never happens during the other three months of the year.
Old Dec 22, 2009 | 05:00 AM
Originally Posted by ForcedInduction
Probably a cracked vacuum hose or sticky transducer. Find the wastegate and follow its hose, looking for cracked or hard rubber joints and replace the transducer if the hoses look good.
Also, a 300TD is a station wagon. The correct name format is 1998 E300. Being a 98, its automatically a turbo model.
Thanx. Stephen.
Old Dec 29, 2009 | 11:45 AM
vavesealtef's Avatar
pull the efi fuse in the engine bay for 30 secs but you might want to find out what the code is
NYC230K
Jul 21, 2011 06:05 AM
95ee320
Nov 27, 2006 05:14 AM
Matz445
Oct 12, 2006 05:39 PM
