engine dies after violent shaking of car
I bought a 1985 500 SEL. Beautiful black. Bought it Thursday. It has been driving fine. Small puddles of oil and tranny fluid on the floor.
The previous owner recently replaced the tranny with a used one.
I have put about 200 miles on it. Tonight, on the way home from work, and on the expressway at 60, The front end start shaking violently. I knew I had a bad tire, so I thought the tire blew out. I coasted off to the side, as the engine died. The car would not re-start. The tires are fine. The oil is still golden in color. Removing the valve cover cap, the cam shaft visibly turns fine. The tranny fluid is red and fine. No silver. The radiator fluid is fine and still green, with no milky residue. No fuses seem to be blown. The engine turns over fine. Not too easy, not too strained. I could not tell if it was getting gas, because it is a 5 litre engine, and has a big flap on the carberator. I pushed down on the flap and tried to peer into the carberator, but I saw no gas with a crank-over. Perhaps the gas squirts under the second flap which is the butterfly one?
Any ideas?
Any ideas?
RE: engine dies after violent shaking of car
sounds like a fuel pump problem - revisit the fuse panel - if it is those foreign types, they can wear out on the tips, causing poor conductivity - some cars have a rollover switch which opens the fuel pump ckt in case of accident/ rollover - if there is one, it may have malfunctioned - i don't have a lot of info on mercedes - just what i have felt out on mine also, have you thought it might be a plugged up fuel filter? pat
95e320
10-09-2012 12:09 AM
