EC mode is stuck on-NO AC?
Has anybody had the EC mode on the climate control panel get stuck on? My AC has stopped working since this happened and I'm not sure how to un-stick it. Also, where do you get the tools to remove the claimate control panel should I need to replace it.
Thanks,
Jerry
Thanks,
Jerry
In many cases, the refrigerant pressure/temperature sensors, if faulty, can cause this condition. If there is pressure in the system, but the sensor is not working properly and not seeing that there is adequate freon in the system, it will also cause this light to stay on. I would look for that and or a leak from the hose near the receiver/drier.
JBergenske
12-04-2008 07:50 PM
