Driver's window C class won't raise
Old May 16, 2011 | 11:23 AM
Cliffduvall's Avatar
Default Driver's window C class won't raise
I have a 1996 C class on which the driver's window won't raise. No current goes to the motor when I push the button to raise it. As a matter of fact, no current goes to the relay in the conveniece control module located in the trunk when I push the button to raise the driver's window. I removed the switches from the console and cleaned them the tested the switch and it is good. I have checked the fuse for front window raising and it is good. The passenger window goes up and down just fine. This problem has stumped me... Help!
Old May 16, 2011 | 02:44 PM
MmmCedes's Avatar
did you check the wiring? Could be bad wiring.
ifthecar
May 12, 2013 02:07 PM
Cliffduvall
May 19, 2011 09:12 AM
Renato
Aug 25, 2010 08:08 PM
blackbenzsl500
Oct 20, 2008 03:27 PM
dhs9
Jan 15, 2006 12:05 PM
