dashboard lights
Old May 20, 2009 | 05:22 PM
hondo's Avatar
Default dashboard lights
the dashboard lights will not work on my 1982 300d i have changed all the fuses so its not that .Can someone help?
Old May 20, 2009 | 06:40 PM
cycleboy's Avatar
Pull the dash and use a continuity tester to check the power delivery to the connector that plugs into the dash. If that tests good, check the bulbs.
Old May 20, 2009 | 07:30 PM
hondo's Avatar
how do i pull the dash ? I could not find any way to get it off . thanks
Old May 21, 2009 | 06:44 AM
cycleboy's Avatar
Remove the kick panel then reach up behind it and push the console forward. It will pop right out.
Old May 21, 2009 | 11:34 AM
hondo's Avatar
thanks you have been a big help.
slick1
Jul 30, 2007 07:05 PM
dherting
May 20, 2005 02:46 PM
Cheesehead
Feb 27, 2005 12:47 AM
jon121
Feb 18, 2005 09:11 PM
nineknot
Feb 14, 2005 12:01 PM
