crankshaft bolt removal c280
Old Jul 22, 2006 | 03:13 PM
wilbur1's Avatar
Default crankshaft bolt removal c280
What is the trick to getting the crankshaft bolt off at the harmonic balancer on a 1996 C280. I don't believe it is a left hand thread. It won't budge. I am trying to replace by front seal.
Old Jul 22, 2006 | 09:03 PM
rmf0102's Avatar
Default RE: crankshaft bolt removal c280
u need the special tool to hold the crankshaft pully, or u could get a breaker bar put your 27mm socket on, put the breaker bar on the bolt and turn the whole thing until u have the bar against the frame, hop in the car and tap the engine over. make sure u have the bar on the correct side so it doesnt damage anything.
Old Jul 25, 2006 | 11:14 AM
SIMONL380's Avatar
Hi: Any luck removing the harmonic balancer? I have the same problem on my 1985 380SE. Did you find out if the bolt is left hand or right hand thread? Let me know if you don't mind?. Thanks
maxbenz79
Nov 2, 2011 08:35 PM
stess
May 8, 2008 12:30 AM
deemerc
Jun 16, 2007 07:33 PM
SIMONL380
Jul 29, 2006 07:43 AM
wilbur1
Jul 23, 2006 11:33 AM
