cam chain tensioner bolt removal
Old Jun 10, 2007 | 02:34 AM
deemerc's Avatar
Default cam chain tensioner bolt removal
Hi All,
I am removing the head off my 1978 230. 4 cylinder petrol merc, w123
For the life of me I cannot seem to remove the bolts or should I say inner threaded stud type set up that holds the static side of the cam chain guides in place, those that know them will know they are a flush face stud that has a 6mm internal thread, I have tried without gain to screw in a 6mm bolt with a nut on it and tightened up the bolt hopping to then back out the cam chain guide stud, no luck, are these left hand thread??
Any help would be very welcome.
Old Jun 10, 2007 | 09:30 AM
BlueSilver's Avatar
Default RE: cam chain tensioner bolt removal
Hi deemerc,
Look your part up on the internet to see if even has threads on the other end. Are you sure its not simply pressed in?
Blue
Old Jun 16, 2007 | 07:33 PM
harasteh's Avatar
on 3.2 ltr , 1993, I used a bolt and a socket ,firstI used sliding hammer but the right bolt and socket at the end didthe job. use planty of W40 or brake fluid. make sure to masure the dept.
huskerden
Mar 27, 2014 11:22 AM
StephaneD
Jul 31, 2011 10:57 AM
SV27
Apr 9, 2007 04:50 PM
SV27
Apr 9, 2007 04:48 PM
PANSSER
Dec 27, 2004 01:26 AM
