consumer battery warning
Old Jun 17, 2008 | 02:26 PM
alragins's Avatar
Default consumer battery warning
I have a 03 E320 with 48,000 miles. The consumers shut off warning continues toappear, however, everything works except thesummer window option.Do I need a new battery?
Old Jun 17, 2008 | 06:46 PM
will3hawks's Avatar
Default RE: consumer battery warning
Sounds that way; many German cars have a failsafe mode wherein the electrical system will shut down all nonessential functions as battery voltage drops. Get it checked.
Old Jun 17, 2008 | 07:44 PM
gilgorm's Avatar
If the warning is correct, the battery is the obvious problem but at the same time check out the alternator. Some of your accessory buttonsmay blink (heated seats) etc. when there is not enough "juice". If and when the battery fails completely, the car will turn itself off and roll to a stop. Not an appealing thought on the highway.
Old Jun 18, 2008 | 04:00 PM
BLUETEAM's Avatar
Possible battery control module issue. Dealer can diagnose within an hour. Dont forget 211 has an auxilliary battery under the hood.
Old Jun 19, 2008 | 12:18 AM
KSpeed's Avatar
Most likely you'll need a Auxilliary battery and check for newer software updates for BCM
Old Jun 23, 2008 | 12:20 PM
alragins's Avatar
I took the car to MB dealer and was told that the problem is the battery control module. I will let you know how it goes when I pick the car up today.
Donovano
Jan 27, 2011 01:29 PM
Donovano
Dec 13, 2010 02:21 PM
mgr1001
Mar 7, 2008 11:46 PM
sc4259
Jul 2, 2006 02:11 PM
sc4259
Jun 26, 2006 03:25 AM
