CLK ALTERNATOR
Hey guys,
I came up to a problem with my clk, i think the alt is bad, when i hit the lights on and off there is a big loud sound coming from the altenator housing, also a constant squeaking noise that can be heard at all time when the engine is on.
How hard is it to change the alt, also is there a way that i can spray a WD40 or something like stop belt squeaking spray or what should i do guys.
thanks
CLK
thanks
CLK
For information alternator removal is not hard at all. It's one of the simplest jobs. WD40 probably would cause more problems than solve em on a belt or alternator. Ususally a squeaking noise when the engine is running is usually a loose belt. That squeak is an easy fix.
ORIGINAL: CLK500KID
Hey guys,
thanks
CLK
Hey guys,
thanks
CLK
hope this helps
Hey guys,
the thing is not squeking, its more of a humming noise, i checked the belt and it is in good condition. I have looked at the other pulleys and they seem not to be making the humming nosie. the other thing is that when i am at a stop light, the humming noise is a costitant beat. even when i rev the engine high the noise is at the same beat. then when i go to put on all the electronics int he car at the same time, the noise is still there, even with the engine interuption in rpm.
The system is still recharging since i have drove it like for a week now and its still the same.
So what should i look for, the bearing inside or the pully on the alternator, or something else
thanks,
Clk500kid
thanks,
Clk500kid
it's okay for up to two minutes. this will avoid overheating the engine.
while the belt is out, you must spin every pulleys where the belt goes and try to wiggle them. observe for any movement or noise.
if the noise is gone, then it must be from one of those belt driven component... but if the noise is still there, then it can be from the engine or others.
