clk 430 brake light warings
Old Mar 18, 2006 | 06:26 PM
muhamet's Avatar
Default clk 430 brake light warings
i put my car away for the winter and the battery died and i did not know that and i went to start i and it told me i had 2 problems with the brakes (abs) and (bas) brake asist system lights came on any ideas on what to do it says to go to the dealer work shop thanks alot on the help
Old Mar 19, 2006 | 01:15 AM
C280 wizard's Avatar
Default RE: clk 430 brake light warings
If your going to store your car for the winter, which IMHO is a Why question? Cars are made to be driven. I drive my 79 450SLC in snow. I was the undercarriage a lot at the self serve car wash.
But anyway.You need a battery trickle charger that shuts off when the battery is fully charges and restarts when it goes below a predetermined amount of volts. I have one for my 99 C280 as it gets driven once or twice a week and usually a city jaunt. The Battery Tender Plus is the one I have. You need to be close to an electric outlet and don't forget to unplug it. I did once and pulled half of the grille off the car. The Tender is easy to install and no maintenance and it runs itself. Prices range for $39.95 to $59.95. As far as the brake lights, it could be from the dead battery, and they need to be reset. Have you driven the car? I assume the brakes work?
Old Mar 19, 2006 | 01:55 AM
Laterthatsameday's Avatar
Start the car and turn the steering wheel from lock to lock, it will probably relearn the steering angle sensor.
rajeevkak@hotmail.com
Jun 23, 2012 03:07 PM
danbulktek
Oct 5, 2009 03:58 PM
rhm
Mar 17, 2008 10:52 AM
CanadianEh
Oct 11, 2005 06:16 PM
