Clk 320 Cabriolet Trans fluid
Old May 7, 2011 | 11:31 AM
Alliycat's Avatar
Default Clk 320 Cabriolet Trans fluid
The trans acts like it may be low on fluid, and the manual says take it to the dealer to have it checked. Right! Like I want to spend $200 to have them put 3 buck worth of oil in the tranny. I found what appears to be the fill pipe, at the left, rear of the engine. It has a cap with "Factory only" or something to that effect on it. Is this the filler pipe? Also, is there a fluid level plug on the transmission case, or does the factory man just run a wire gage down the filler pipe? Any help will certainly be appreciated.
Old May 8, 2011 | 08:43 AM
Alliycat's Avatar
Red face
Originally Posted by ForcedInduction
Thanks so much. Now for the next question that I should have included in my original post: What type fluid does it take? Dexron, Type F, or ?????
Old May 9, 2011 | 10:27 AM
Alliycat's Avatar
Thanks for your help ForcedInduction. We'll get the ATF changed ASAP.
bballfreak
Jan 13, 2011 06:42 AM
pino
Dec 8, 2008 07:26 PM
pino
Dec 7, 2008 08:32 PM
Stanbulgaria
Mar 20, 2008 04:10 PM
tcouch
May 31, 2007 06:51 PM
