Car won't start. Need help!
Old Aug 6, 2013 | 07:43 AM
termigator's Avatar
Default Car won't start. Need help!
I have a 95' E320 that won't start. When I turn the key, nothing happens. engine and battery lights are on and the battery seems fine, but nothing happens. There is a humming/buzzing sound coming from the general area around the left AC vent and light switch ****. Any help/suggestions would be greatly appreciated!
Old Aug 21, 2013 | 09:07 PM
go-part's Avatar
Former Sponsor
Have you checked all of your fuses and relays?
Have you had your battery and starter tested?
http://www.ifitjams.com/starting.htm
Old Sep 22, 2013 | 04:51 AM
BigSkyBenz's Avatar
Hello! I have faced the same problem couple of days ago. Like you when I turned the key it just switched on the lights and else nothing happen. Then I thoroughly read the diagnostic flow chart and doubled check the fuses. I checked the battery as well and happily this was okay. I recommend you to read the starter diagnostic flowchart.
Goldengirl1
Nov 8, 2012 07:28 PM
lanaca
Feb 16, 2009 04:06 PM
davidmlee
Jan 21, 2009 05:23 PM
Rolex_07
Jan 11, 2009 12:29 PM
vovpar
Dec 24, 2006 04:45 PM
