Can't Get Head Off
Old Feb 17, 2011 | 09:28 PM
cbassoc's Avatar
Default Can't Get Head Off
I have a 1992 190e 2.3
I have taken the 10 head bolts off, found and taken the three smaller bolts inside the timing chair cover compartment, disconnected the exhaust and the intake, I have taken the cam sproket off, and still the head won't budge. Is there another step I am missing? I don't want to force it.
Do I have to remove the tensioner? Do I have to remove the timing guide pins if I already have the chain broken? I don't think these things would effect the head being lifted off.
Thanks in advance.
Old Feb 19, 2011 | 04:16 PM
g.woods's Avatar
yes you have to pull out the timing chain guide rail pins as these pass through the head to hold the rail.is the head a little loose?if you take out the tensioner you would not need to split the chain and you should allways reset your tensioner after.
Old Feb 19, 2011 | 04:37 PM
cbassoc's Avatar
Thanks. What did you mean if I took out the tensioner I would not need to split the chain? Would it allow enough play so I could remove it and replace the chain without having to break it and thread a new one in it?
Old Feb 19, 2011 | 04:38 PM
cbassoc's Avatar
update: On some 190e engines, there is a bolt near the sensors on top of the head, it doesn't look like a head bolt, but it goes completely through the head into the engine block. This bolt is what stumped me. I pulled that out and the head just popped right off.
JGHowland
Aug 5, 2010 08:13 PM
mbz300sdl
Jan 28, 2006 12:12 AM
coach78
Dec 16, 2005 01:58 PM
tobyd
Oct 4, 2005 11:30 AM
C240AWD
Sep 8, 2005 05:24 AM
