Blower Regulator Product Announcement
Old Aug 14, 2006 | 01:14 PM
utnj's Avatar
Default Blower Regulator Product Announcement
UnwiredTools is pleased to announce the availability of our new UTBR Blower Boost Regulator products for Mercedes Benz vehicles. This product replaces the blower regulator on Mercedes 140 and 210 chassis models. The UTBR-140â„¢ and UTBR-210â„¢ are drop-in replacements for the OEM versions. The UTBR are much more efficient and run cooler than the OEM part which means better reliability. Both versions provide a full 12V to the blower when set to maximum which increases the airflow by about 20%. This increase is a welcome upgrade to the A/C systems in hot climates.
The UTBR210â„¢ version is intended to replace the troublesome early (1996 through 1998) 210 chassis blower regulators. The OEM replacement also requires the replacement of the blower, blower housing, filter, and cover. The UTBR-210 uses the stock blower and housing, saving hundreds of dollars in un-needed replacement parts.
You can learn more by visiting UnwiredTools @ http://unwiredtools.com
Old Sep 11, 2006 | 08:15 PM
97dmsrS420's Avatar
Default RE: Blower Regulator Product Announcement
Thanx for the tip.
yngrvp
Aug 5, 2006 10:58 PM
teal854t
Mar 22, 2006 10:16 PM
nineknot
Feb 12, 2006 04:11 PM
utnj
Sep 16, 2005 01:10 PM
cepope99
Jun 18, 2005 12:48 AM
