Blower comes back on after ignition is turned off 2006 R 350
Old 12-11-2011 | 09:04 AM
w10goo's Avatar
Default Blower comes back on after ignition is turned off 2006 R 350
looking for fuse diagram (mine is unusable somehow got wet in spare tire compartment) Want to pull fuse and disble the front blower until I get it to the shop--kept running until battery went dead
Old 12-11-2011 | 01:29 PM
chassis221's Avatar
You probably have water getting into your blower motor... if you have leaves clogged up on your windshield wiper cowl.... you probably have a water down in your blower motor.. although it could just be a bad motor or regulator. the easiest thing to do is remove the passenger side lower dash panel. then you can un plug the blower motor.
Old 12-12-2011 | 07:06 AM
w10goo's Avatar
Default blower stopped by itself
turns out that the battery wasn't dead after all --apparently the blower stopped by itself (amazing how long that blower ran on battery)-- started car and warmed it up-blower came on and went off when ignition was turned off perfectly. I emptied the air scoop which was clogged and full of water as you predicted -trickle charged the battery over night and have my fingers crossed.
thanks again
Don's ML
07-26-2012 11:25 AM
phidelt0135
06-23-2011 04:38 PM
mdvanacore
11-13-2008 02:10 AM
chicagoc320wagon
07-29-2008 11:13 AM
nagy1106
04-21-2006 04:17 PM
