Battery changed, and now Window Problems
Old 02-19-2007 | 06:12 PM
cade111's Avatar
Default Battery changed, and now Window Problems
1999 E320 Wagon
I had to change my battery last week, when complete I had a problem with my power windows. The windows will go up and down, however the auto function of the switch is inop. If you press the switch hard the window will stop, when you let off it will continue up or down which ever direction you are going.
This could be a coincidence with the battery change, but I am stumped. Any help out there?
Cade111
Old 02-19-2007 | 06:25 PM
gasdude's Avatar
Default RE: Battery changed, and now Window Problems
You need to recal them, posibbly the sliding sunroof if installed, and the Stabilitysystem.
All of this is covered in the owners manual.
Ron
Old 02-19-2007 | 06:45 PM
cade111's Avatar
Thanks Ron I will look....
Old 02-20-2007 | 08:53 PM
Zacman's Avatar
Try holding down the switch in the down position for a few seconds after the window is all the way down, if this works on one continue with nthe others
jbphoenix
09-10-2011 08:44 AM
PaulBennett
10-03-2010 12:54 AM
dxprince
02-03-2007 08:32 AM
NoFear10199
11-15-2004 06:11 PM
