Ball Joints and Lower Control Arms
Old Nov 21, 2011 | 05:19 PM
Pamela14's Avatar
Default Ball Joints and Lower Control Arms
'99 C230 Kompressor, 88,000 miles, very well maintained. Should I need new ball joints and lower control arms due to failing bushings at this time? If so, what should I expect to pay for repairs?
Thank you.
Old Nov 21, 2011 | 06:24 PM
chassis221's Avatar
youll only need them if they have play....or are leaking oil from them. generally if the bushings are badly cracked then they should be replaced. lower ball joints will have excessive movement and you can usually hear them over bumps. both can fail state inspection if bad enough.
Old Nov 22, 2011 | 06:55 AM
Pamela14's Avatar
Thank you! What would the reasonable cost to repair approximately be?
natetrook
May 31, 2010 06:14 PM
philipk2003
Dec 8, 2009 12:11 PM
derm
Mar 19, 2006 01:54 PM
kybenz
Jul 18, 2005 09:37 PM
97c230
Mar 10, 2005 12:14 AM
