Air Conditioning Freon Recharge
Old Jun 9, 2005 | 04:26 PM
jab's Avatar
jab
Default Air Conditioning Freon Recharge
1980 300cd
AC System converted to R134a by a licensed and authorized MBZ repair facility in 2001.
Statement : I purchased a can of r134a and supply hose (1) kit (Quest 401P.
No pressure gages included.
Question: Can you instruct me the proper and safe way to top off my AC system.
i.e. conection, setup, procedure, engine status, rpm, state of recharge freon can (light, heavy, cold -etc).
As you can determine - my first time, I want to do it myself to save money, but I do not want to screw up.
The AC system is working fine, just not as cold as it was last summer.
Thanks. John
Old Jun 9, 2005 | 11:04 PM
sleepwalker's Avatar
Default RE: Air Conditioning Freon Recharge
there is a sight glass on top of filter/drier bottle.
once the bubble is not present, it is fully charged.
charge from the low side.
Old Jun 10, 2005 | 02:29 PM
Lugnut's Avatar
To add to sleepwalker's post...
- Fill while the engine is running and the A/C is on.
- Keep freon can upside down while filling. Shake gently a couple of times during filling.
- If one pound doesn't top it off, two should.
- As sleepwalker said, use the low-pressure connection. It's the only one your kit will fit on. The high-pressure connection looks the same but requires a larger fitting. If you somehow managed to "force" a connection there, the refill can of freon would explode.
Old Jun 11, 2005 | 02:23 AM
jab's Avatar
jab
Thank you for the information and time.
Best Wishes, John
Old Jun 11, 2005 | 02:25 AM
jab's Avatar
jab
Thanks for responding and the advice.
Best Wishes, John
pseverin
Aug 7, 2018 06:57 PM
siox12
Jun 16, 2009 03:42 PM
brudd
Apr 27, 2009 03:44 PM
benzman2000
Mar 25, 2007 03:13 PM
kevinrea
Aug 14, 2005 06:53 PM
