Air Conditioning Freon Recharge
1980 300cd
AC System converted to R134a by a licensed and authorized MBZ repair facility in 2001. Statement : I purchased a can of r134a and supply hose (1) kit (Quest 401P. No pressure gages included. Question: Can you instruct me the proper and safe way to top off my AC system. i.e. conection, setup, procedure, engine status, rpm, state of recharge freon can (light, heavy, cold -etc). As you can determine - my first time, I want to do it myself to save money, but I do not want to screw up. The AC system is working fine, just not as cold as it was last summer. Thanks. John |
RE: Air Conditioning Freon Recharge
there is a sight glass on top of filter/drier bottle.
once the bubble is not present, it is fully charged. charge from the low side. |
To add to sleepwalker's post...
- Fill while the engine is running and the A/C is on. - Keep freon can upside down while filling. Shake gently a couple of times during filling. - If one pound doesn't top it off, two should. - As sleepwalker said, use the low-pressure connection. It's the only one your kit will fit on. The high-pressure connection looks the same but requires a larger fitting. If you somehow managed to "force" a connection there, the refill can of freon would explode. |
Thank you for the information and time.
Best Wishes, John |
Thanks for responding and the advice.
Best Wishes, John |
