Air Con on 1997 SL
Old Jun 25, 2007 | 02:59 AM
Davehu6's Avatar
Default Air Con on 1997 SL
Howdy!
My air con blasts out freezing air (even if I have it set to 31 degrees). Then, if I floor the throttle (which obviously I would never do!)the air comes out really hot and starts working perfectly...
Guessing this is a power supply problem...?
Any ideas what iscausing this / how I can fix it?
Many thanks!
Old Jun 25, 2007 | 03:32 AM
snanceki's Avatar
Default RE: Air Con on 1997 SL
Just a stab in the dark. Duo Valve?
This is the electrical solenoid(s) that allows hot water into the hearter/air con unit in the car.They are Open when energised.
Since the pressure in the water system is greater once the engine is doing more revs this may explain the apparent solving of the problem when you "floor" the throttle. i.e. restricted / partial flow.
The Duovalve can be taken apart. Usually the problem is due to corrosion between the moving metal cylinder and the electric magnet. Clean, lightly lubricate etc.
Alternatively it could be the electrical supply (pulse) that is wrong but i favourthe former.
Stuart.
Old Jun 25, 2007 | 05:01 AM
Davehu6's Avatar
Thanks for the reply! I will look into that....
It's not too bad at the moment but want it sorted before winter!!! [sm=thanx.gif]
ziggytwizzer
May 7, 2007 06:15 PM
diamond geezer
Dec 10, 2006 04:09 PM
bullockandrew
Jun 16, 2006 03:09 PM
Andy G
Feb 2, 2006 07:25 PM
careofsam
Mar 21, 2005 04:41 PM
