Vin Decoder
or
Login with Facebook
ABS BAS lights
Post general Mercedes Tech questions here.
ABS BAS lights
06-25-2007, 07:57 AM
beastie40
RE: ABS BAS lights
To all that tried to help, after going for a codes dia check, the fauilt was a ABS sensor.
BUT A BIG THANK YOU TO ALL THAT TRIED TO HELP
beastie40
Find all posts by beastie40
12
06-25-2007, 01:18 PM
snanceki
RE: ABS BAS lights
Is that not the diagnosis that i gave as the most likely cause?
Stuart.
snanceki
Find all posts by snanceki
13
06-25-2007, 01:51 PM
beastie40
RE: ABS BAS lights
Well Done Stuart, Give yourself a brownie point! Keep up the good work.
Now how do you fit a new one?
beastie40
14
06-25-2007, 03:04 PM
snanceki
RE: ABS BAS lights
Front sensor held in to hub by one screw + of course you need to disconnect the wiring.
Its that easy.
I assume you know which sensor it is that has gone down from the code reading.
Stuart
snanceki
15
06-26-2007, 01:33 PM
beastie40
RE: ABS BAS lights
Yes it was the right rear. I fitted it in 10mins no problems, road tested it all lights now out, cruise control working now as well.
cheers!!
beastie40
w210 e55 brake lights don't work, and esp bas abs lights on!
e55 ///amg
02:45 AM
How to reset ABS BAS lights ??
scarabexc
12:22 PM
abs/bas lights on whilst driving
elect25245
04:10 PM
BAS, ASR, and ABS lights are on... need help
mj300zx
10:49 PM
1998 C200 Sport ABS and BAS/ASR Lights on all the time
MTA C200 Sport
01:16 PM
Tags
560sl
abs
bad
bas
basasr
benz
brake
drop
fault
light
mercedes
sl500
switch
testing
voltage
yourasr
auxiliary cooling fan problem
Posting Quick Reply - Please Wait
Quick Reply:
ABS BAS lights
The following errors occurred with your submission
Okay
Quote message in reply?
10:22 AM
