98 ML320 water pump help
Old Jun 18, 2010 | 12:51 PM
spujoe's Avatar
Default 98 ML320 water pump help
I have recently purchased a water pump to replace my failed one, and I need help. This is about my hundredth water pump job but mostly all Chevys of varying types and years.
1. What are ALL these bolts?
2. Can somebody post a belt diagram?
3. The first bolts to remove are hex head (?) and the fan is too close too
get an allen wrench in there! Should I use a hex bit from a nut driver set and a wrench (6mm?) to get in there?
4. My part came with the standard gasket with the holes in it but it also came with a rubber gasket or seal with tabs on it that can only go inside somewhere...but where?
5. After the first 4 bolts come off and I get the belt off I see few troubles but what other components must be removed, since I see some bolt sleeves in the holes on the water pump?
ANY HELP AND ESPECIALLY PICTURES WOULD BE APPRECIATED GREATLY!
Old Jun 21, 2010 | 12:07 PM
spujoe's Avatar
I got it done, it wasn't any more difficult than any other vehicle. The clutch fan removal was difficult, it required an air tool to get it off.
ml320cdi-guy
Mar 18, 2013 08:14 AM
Savanh
Aug 27, 2010 07:51 PM
eg_21
Jul 16, 2009 06:45 PM
YuCrew
Jan 3, 2007 09:25 AM
kanio
Sep 15, 2006 04:25 PM
