86 MB 300E neutral safety and testing of the fuel dizzy
Old Jun 22, 2009 | 07:38 PM
volksdriver's Avatar
Default 86 MB 300E neutral safety and testing of the fuel dizzy
I can only start the car in neutral, its an auto tranny with the 3.0L straight six, where is the neutral switch and how hard is it to replace? Also is there a way to test the fuel distributor without expensive tools ?
Old Jun 24, 2009 | 04:24 PM
silverstartech's Avatar
neutral safety switch is on the left side of the transmission. 2 10mm nuts. fairly easy but a tight spot. good luck
Old Jun 24, 2009 | 08:06 PM
88silver300e's Avatar
Default Neutral Safety Switch
Also, be sure to slide the plastic retainer on the switch so you can disconnect it from the linkage. Look at the new one to get an idea of which way it should slide.
StewCRu
Apr 29, 2007 12:57 AM
pguard
Jan 20, 2007 12:52 AM
BlackWolf
Jul 18, 2006 07:43 AM
cdwatnsu
Feb 1, 2005 01:27 AM
lprivee
Nov 6, 2004 07:53 PM
