85 300SD Ignition Switch Problem
Old Sep 20, 2005 | 12:44 AM
captainkurt's Avatar
Default 85 300SD Ignition Switch Problem
The key is jammed inside the ignition switch and can't be removed. It can be turned to off and the first position, but the car can't be started using the key.
In this particular model, inorder to restart the engine after it has been shutoff, the key has to be completely removed from the lock.
I am not even sure how this could of happened, I didn't force it or anything. I suspect somone might have tampered with it trying to rip off the car and damaged
the lock pins. I was wondering if anyone has any suggestions about a solution.
autobuff
Aug 24, 2014 02:44 AM
aser011
Mercedes A Class
May 7, 2010 09:20 PM
Redbones
Apr 25, 2006 12:49 PM
MB300SD
Feb 26, 2005 08:34 PM
dokhans
Jun 29, 2004 06:57 PM
