84 380 sel cutting off when braking
Old Aug 25, 2006 | 11:21 PM
bpeesy's Avatar
Default 84 380 sel cutting off when braking
I have a 1984 380 SEL 224k miles. all of a sudden whenever I'm coming to a stop the car will cut off. The RPM's would just suddenly drop and the car cuts off. Does anyone have any idea what could cause this?
Old Aug 27, 2006 | 06:46 PM
bpeesy's Avatar
Default RE: 84 380 sel cutting off when braking
Help anyone, my 84 sel is still cutting off whenever I'm decelarating. The RPM drops then it cuts off. anyone. hello hello anybody out there.
Old Aug 27, 2006 | 06:54 PM
mbz300sdl's Avatar
Sounds like ur not firing on all cylinders change ur plugs and wires first if that doesnt help let me know.
Old Aug 30, 2006 | 10:03 PM
flednj's Avatar
had exactly the same problem ... took off the idle control valve (easy), put a lot of Gumout in it, shook it up, and it's been running fine for a year .....
good luck ... gerry .. near San Antonio, TX
Old Aug 31, 2006 | 02:44 AM
bpeesy's Avatar
Thank you all, Can anyone explain to me where I would find the Idle Control Valve? Is it somthing that's connected to the
throttle body?
Old Aug 31, 2006 | 09:12 PM
flednj's Avatar
Idle control valve is easy to get at .. open the hood, look down, it's the thing with the two big vacuum hoses and an electrical connector ... kinda looks like it should be a fuel filter ...
give it a good fill of Gum-out ... bang it around some, blow dry it, and do it a few more times ... this amateurish procedure worked fine for me for exactly the same problem ..
if your stalling condition improves, you still may want to then buy a new one, now that you know it's the problem ... this was my plan, although i haven't done it yet after a year ... more pressing issues with the black beauty 380SL...
regards and good luck ... Gerry
northbeachfilms
Jul 28, 2009 02:24 PM
mercfancy
Jul 7, 2009 02:46 PM
jmaupin35
Dec 18, 2008 06:07 PM
sneezy247
Oct 21, 2008 10:46 AM
jonathan ayuba
Dec 2, 2004 12:25 PM
