79 240D loose alternator and belt
Old May 23, 2008 | 11:44 PM
brivie's Avatar
Default 79 240D loose alternator and belt
The through-bolt on my alternator has worked itself out, causing the belt to be too loose resulting in a screeching noise when starting the car. But I cant get that bolt all the way back in. It goes about 4 inches in but just wont thread the last inch. Any suggestions? I think the hole might be full of grease and dirt blocking the bolt from threading in. What do you think? Any tricks to this? Tomorrow I will get in there with a wire brush and clean it out and try it again.
Old May 24, 2008 | 06:12 AM
will3hawks's Avatar
Default RE: 79 240D loose alternator and belt
get yourself a tap an die set and retap the screw holes with the origional size tap
ogaga
Mar 23, 2014 12:57 PM
magg
Oct 24, 2010 10:31 PM
dablk1
Aug 27, 2009 10:41 AM
dacstuff
Mar 16, 2009 10:36 AM
Benz_190
Aug 26, 2005 01:15 AM
