73 450sl Engine dead
Old Oct 2, 2017 | 02:12 PM
H20ham's Avatar
Default 73 450sl Engine dead
looks like I am plunking a used engine in our beloved 450
any thoughts please as to what associated bits should go into a used engine prior to install
such as oil pump...water pump...timing?
kind Regards
james
Old Oct 3, 2017 | 12:38 AM
H20ham's Avatar
Maybe I am in the wrong forum section?
Old Oct 3, 2017 | 12:13 PM
PelicanParts.com's Avatar
Hello and welcome to the forum James! I'm not quite understanding what you're asking. Are you trying to salvage parts from your old engine and apply them to a new one?
Old Oct 3, 2017 | 03:16 PM
H20ham's Avatar
I believe my engine is toast.
used engines may be no better, but I know the costs associated.
So I will keep the old dead engine in hopes of having it rebuilt sometime
my plan is to get the best highest compression used engine
put whatever new bits in it, like water oil pumps chain and tensioners etc
hope I can get another 20 years out of this fine auto
kind Regards
Old Oct 3, 2017 | 03:18 PM
H20ham's Avatar
kind Regards
Old Oct 3, 2017 | 06:36 PM
Thanks for clarifying - have you decided on the engine you'll be using? This needs to be known before we can suggest which parts are going to be compatible.
Old Oct 3, 2017 | 08:46 PM
H20ham's Avatar
I am sure I have found and will purchase tomorrow a 1972 450sl 4.5 with 157 compression (supposedly)
Old Oct 4, 2017 | 12:26 PM
Hi James - that should make it a lot easier for you since you're essentially getting the same engine (for some reason I thought that you were going to get an engine from a different model and try to make it work). To help you, I'm attaching a link to our site's DIY tech articles on the R107 platform. This should make install and maintenance a bit easier for you. Hope this is useful and best of luck!
Mercedes-Benz SL-Class R107 (1972-1989) Technical Articles – Pelican Parts
Old Oct 4, 2017 | 12:31 PM
  #9
H20ham's Avatar
Great resource
Not trying to rush things. I am in Canada and the engine is on order. So I need to be a bit fast ordering parts, as I really only have today.
Outside of water oil pumps. Timing components. Any other bits.
I will take the time soon to digest the procedure.
Old Oct 4, 2017 | 12:54 PM
  #10
No problem at all, glad to help. If you have any questions in regards to parts, please feel free to give us a call at 310-626-8765 and one of our Mercedes parts specialist will be happy to assist you.
Originally Posted by H20ham
Great resource
raitch
Nov 2, 2016 09:35 AM
hallpet45
Aug 19, 2010 09:15 PM
lmarty1359
Dec 15, 2007 11:51 PM
amarcord
Sep 18, 2006 12:30 PM
C280 wizard
Aug 24, 2005 10:41 PM
