722.6 noise.
Old Dec 5, 2005 | 11:55 PM
obwielnls's Avatar
Default 722.6 noise.
I have a 99 S320 W140 with a 722.6 Transmission. Tonight on the way home it started making a noise.. After some basic troubleshooting I know this...
1. The transmission makes noise with car running and gear shifter in neutral or park.
2. If I shift into reverse or drive and dont move the noise goes away.
3. If I start moving the noise comes back..
The noise sounds like a rattle with in park or neutral. When moving it sounds much worse like gears clashing and you can "feel" something hanging as the car moves forward..
I have found a rebuilt unit from a company in AZ but I am worried that they will keep my core charge because there is something very wrong with this one..
Does anyone have any ideas what might have happened to this thing? I can replace the transmission myself but if its something not too bad I might be temped to take it to a transmission shop..
Thanx in advance.
Bill
Old Dec 6, 2005 | 12:03 AM
sleepwalker's Avatar
Default RE: 722.6 noise.
i have o/h a transmision with the same problem and costs about $800 on the parts.
it can be fixed, but got to replace many things esp the clutch housing which is rubbing and makes the noise.
Old Dec 6, 2005 | 12:05 AM
obwielnls's Avatar
Thanx for the fast response.. Do you think this is something that would keep my from getting my core back?
I can fix most anything.. are there any special tools that are required?
Is this common for this model?
Old Dec 6, 2005 | 12:13 AM
what do you mean by "core"?.
yes, you can fix it even in your backyard. once you pull up the upper half, everything is exposed. then it is composed of 3 components which is easy to remember. no special tools required, just another person to help you push the spring plate down while you do/undo the lock ring.
not common, but you can expect many things from worn out AT.
obujdei
Jul 18, 2011 03:24 PM
totx
Oct 25, 2007 06:01 PM
finchy
13
Jul 1, 2007 04:28 PM
nice560SEL
May 30, 2005 09:31 PM
ezeneli
Apr 8, 2005 03:05 AM
