380SL Hard Starting
Old Sep 6, 2005 | 09:44 PM
TBenedikt's Avatar
Default 380SL Hard Starting
I noticed today that my tach was acting stangely. If I increase the RPM's up to 1500 RPM in neutral the tach begins to swing up and down from 1500 RPM up to 2500 RPM. If I then put the car into gear at its normal 650RPM idle speed the car will stall and be very hard to start afterwards. If the tach does not swing up and down then the car acts totally normal. I would appreciate any direction anyone could give me.
Old Sep 6, 2005 | 11:34 PM
sleepwalker's Avatar
Default RE: 380SL Hard Starting
during the erratic tach movement, the engine is also fluctuating (RPM)?
tach is connected to ignition coil. check that out.
tarrantb
Dec 3, 2010 01:25 PM
Benzmama
Sep 12, 2009 07:44 PM
83_380sl
Oct 5, 2005 11:27 PM
2w7don2
Feb 26, 2005 02:50 AM
volksoholic
Feb 3, 2005 10:18 PM
