300sd blower motor volt
Old Nov 17, 2006 | 04:41 PM
CRANDSR's Avatar
Default 300sd blower motor volt
83 300sd blower moter voltage zero with wire connections ON, measured wire connections (disconnected) at 12V, jumped fan motor directly to battery - works fine, 30 amp fuse OK Please advise
Old Nov 22, 2006 | 12:12 AM
otm646's Avatar
Default RE: 300sd blower motor volt
clarify:
you have power to the leads which connect to the fan, and when you jumper the fan from an external source it spins. yet when you connect the powered leads to the fan you get no rotation?
xb70valkarye
May 8, 2026 08:01 AM
71inka02
Nov 13, 2008 09:10 PM
sfk
Feb 8, 2007 11:53 AM
Ellen Ward
Dec 13, 2006 06:02 PM
jonsterTJ
Jan 13, 2006 01:31 AM
